17寸触摸屏显示器
Product type:17”LCD Monitor + 4 wire Resistive Touch Screen
Touch panel Specification:
Part No: T-Touch T8550FG
Monitor Specification:
u Model No: KTC 5005L serials
u Size of LCD Panel: 17”LCD
u Pixel pitch : 0.264x0.264mm
u Max Resolution:1280x1024@75Hz
u Display area: 337.920x270.336mm
u Color: 16.7M
u Contrast ration: 500/1
u Brightness: 300cd/m2
u Response time(Tr/Tf):12/4 ms
u View angle, R/LU/D: H:-80°/+80° V: -70°/+70°
u Input signal: Analog RGB; DVI(optional)
u Scan frequency: H:30K-81KHz V:55-75Hz
u RGB Model OSD: 25 function
Six Languages /color/position/clock/phase/sharpness/OSD transparency/OSD positiontime / contrast / brightness/recall/auto adjustment/volume
u Power Adapter Input: AC 100V to 240V 50/60Hz
u Power output: DC 12V
u Power consumption: <40w
u Operation Environment:
Temp. 5℃~40℃
Humidity: 10%-85%
Pressure: 86kpa-104kpa
u Plug & play: VESA DDC2
u Power management: VESA DPMS
u Built-in speaker: Yes
u Wall amount (VESA standard): YES
u Dimension (H*W*D):440x455x165mm D: Thickness Weight (w/stand):7kg
u Control button on front frame: four press key
u Accessory package: VGA cord, power cord, adaptor user manual
u Safety & EMI: CE, FCC,CB, TCO99,UL(in applying)
